Roland FC 300 and PitchFactor … ?
Home Forums Products Stompboxes Roland FC 300 and PitchFactor … ?
Viewing 3 reply threads
    • #106163
      Ghost
      As I own this MIDI pedal for my Roger Linn Adrenalin I hope someone can tell me if I could do without the expressionpedal and use MIDI CCs instead.
      I hope I don't have to do this for every preset and can only set this up once.
      Many many thanks for helping,
      Martin aka Ghost
    • #118470
      achaput
      You can assign a MIDI Continuous Controller Number to "PDL" in PitchFactor's MIDI menu and then that MIDI CC will behave like an expression pedal plugged into the Expression Pedal input.
    • #118471
      Ghost
      Great that's what I thought but since it only said pedal ( not foot or expression pedal ) in the manual I was a bit confused since PDL could also be just latch or unlatch switches.
      It's solved now, I'm a happy man … ,
      Martin aka Ghost
    • #120436
      Teo Ederle
      hi, I'm new entry and I have pichfactor connected directly with roland ev5 exp ped… Also I have roland fc 300.
      have a question:
      exist a default midi cc list? I would prefer to adapt the pedalboard to the pitchfactor without use the learn option.
      thanx & regards
