Rose 3.9 Version Warning
Home › Forums › Products › Stompboxes › Rose 3.9 Version Warning
Viewing 3 reply threads
    • #115880
      buickwilson
        I bought a new Rose pedal today that had version 2.30 loaded. I installed the EDM app 1.33 running on a iMAC Pro with Catalina OS. I then updated the Rose,  first to 3.11 then 3.9. Both updates finished ok and the Rose rebooted, but when I try to select “Get System / Presets”, I get a “Version Warning” alert below.
        I tried re-updating 3 times, but no change. Any suggestion on what I should do?
      • #154660
        bohan
          I tried to reproduce your issue. I could see this warning window if my Rose is 3.9. I updated it to 3.11 then it worked fine. Could you try updating it to the latest again?
        • #154663
          buickwilson
            My fault (need better glasses). I saw  it as 3.1.1, so I figured 3.9 was the lates. Duh on me it’s 3.11. This works fine.
            Thanks for the quick response.
            Great pedal. Neil
          • #156142
            lol  good one!
