Home › Forums › Products › Stompboxes › Rose Pedal, High pitched noise
- This topic has 8 replies, 3 voices, and was last updated 3 years, 3 months ago by
Keoki.
December 3, 2021 at 8:58 pm #161140
I am looking for the source of the high pitch sound coming from the rose, I am adding a link to a video showing the issue, set up is: Guitar straight to the rose and the amp input, running in the stereo effect loop provided by Orange Rocker 32, Eventide H9, Strymon Big Sky, the noise happens regardless of where the rose is positioned, fx loop or in front of the amp.
December 3, 2021 at 9:07 pm #161141
Does the noise manifest when you disconnect the USB cable from Rose?
December 3, 2021 at 9:15 pm #161142
(edited original reply)
It is still there,
I really appreciate your quick response, I like to understand why, additionally I do a lot of recordings and find it usefull to edit the pedal while I am working, how do I avoid the issue allowing me to edit “live”
December 3, 2021 at 9:40 pm #161143
Having the USB cable connected to the pedal is causing a ground loop in your system. The only way to prevent this from happening is somehow isolating the pedal from computer, which is not an easy thing to do. You can try to use a USB isolator though I have not tried one myself. It’s best to just only connect the pedal when you need to use EDM.
December 3, 2021 at 9:46 pm #161144
If the noise is still there, then I recommend contacting support@eventide.com and sending them the same video. They can take you through some further steps to diagnose the problem. They’ll probably ask you to backup your presets, reinstall the firmware, and conduct a factory reset.You can try that now, but if that doesn’t fix the problem, the unit may need to be serviced, though this is the first time I hear a squeal of this nature.
December 3, 2021 at 9:49 pm #161145
I will try,
Once I unplugged the USB the noise went away but it came back while unplugged from the USB cable, this issue just started two days ago, I had it going thru the fx loop without any issues while being plugged in, suddenly it started doing it.
December 3, 2021 at 10:14 pm #161147
Looks like it was under-powered, it was connected to the eventide max, now its running isolated and very quiet, Thanks for the help.
December 4, 2021 at 12:16 pm #161150
amazing what undercurrent can manifest…
December 3, 2021 at 10:16 pm #161148
That’s great information. I appreciate you reporting back. Glad you solved the problem. Enjoy making music!
