Home › Forums › Products › Stompboxes › Rose pedal scrolling
June 2, 2020 at 4:05 pm #115941
jac
ParticipantI really would like PC or CC for scrolling up & down. Anyone else feel the same?
June 2, 2020 at 6:13 pm #154995jac wrote:I really would like PC or CC for scrolling up & down. Anyone else feel the same?
Rose does support MIDI PC. You may also use an aux switch to scroll up and down presets. More info:
https://com-eventide-drupaluserfiles.s3.amazonaws.com/download/file/Rose-QRG-Rv21.pdf
https://www.eventideaudio.com/support/downloads/rose-user-guide-addendum-v3
June 2, 2020 at 6:51 pm #154996
jac
Participantbohan wrote:jac wrote:I really would like PC or CC for scrolling up & down. Anyone else feel the same?Rose does support MIDI PC. You may also use an aux switch to scroll up and down presets. More info:
Yes, I’m aware of all you mentioned. But, I only have room for a midi baby 3 on my board. Which is controlling my H9 & Rose. The Rose does accept PC commands but there’s nothing designated for up & down. My other issue is the MB3 doesn’t have a scroll mode. I wish the Rose had the midi capabilities of the h9.
June 3, 2020 at 12:30 am #154997
Participantjac wrote:… My other issue is the MB3 doesn’t have a scroll mode ….Interested bystander, but no MB3 here. Just working from the MIDI Baby 3 Editor, so correct me if I’m wrong.
I see a count & send option for a Program Change. Start & Stop PC; Step; Count to configure. That should get you incremental presets on a switch action, scrolling upward. I don’t see negative number entries, so I’m not so sure about scrolling down.
Send Single Value (or Send Counter?) could bring you back to a starting point preset [PC #1 of 25, for example). I don’t see where that Editor currently supports programming more than one Main Footswitch, though.
June 3, 2020 at 2:57 am #154998
jac
Participantbrock wrote:jac wrote:… My other issue is the MB3 doesn’t have a scroll mode ….Interested bystander, but no MB3 here. Just working from the MIDI Baby 3 Editor, so correct me if I’m wrong.
So, I did what they recommend. You can send multiple PC commands (PC0 thru PC6) in sequence on one switch to scroll up on the MB3/Rose. Then I just assigned (0-6)PC numbers I wanted to H9 presets. But, there’s no scrolling down you have to cycle thru all 7 commands. With this method you lose the hold & long hold on MB3.
If the pedal had scrolling on a specific PC or CC number, you could just use those commands to scroll up/down. Then I could go to the H9 & just use the same PC or CC numbers as the Rose to scroll up/down.
