Rounting the presets
Home › Forums › Products › Rackmount › Rounting the presets
Viewing 3 reply threads
    • #109508
      Dario
        Hi, many presets of my unit ( H8000FW 5.5), are  <Summed in, stereo out>, in this case how should  I have to set the IN's of the DSP A and B ?
        thanks
      • #124208
          If it is "summed in" it means that it will work with mono or stereo in, to give a stereo out. This is common with reverbs.
          How to route it depends on your signal source, but any appropriate routing should do.
        • #124221
          Dario
            Ok, in my case, my  "Summed in" example  is referred to a preset like the # 6523 TC2290,
            this is my general setup:
            1) guitar
            2) rack guitar stereo preamp
            3) Mackie 1604 VLZ3
            4) Eventide H8000FW
            This is the way in which I route the signal:
            from one Output of my guitar Preamp I go in one mixer's channel,from the second Output of my preamp I go straight into the Analog Input 1 of the H8000.
            My Mackie mixer has 6 Aux Sends knobs, I utilize  one of these Aux sends to feed the Analog Input 2 of the H8000, So, my Eventide two analog inputs ( 1 and 2) will be feed from a stereo source, the first coming from my preamp Out and the second one coming from the Aux send of my Mixer.
            In this scenario, by utilizing an "Analog A->B" or "Analog A||B" routing, I've noticed when if I feed my TC2290 preset with mono, that is only utilizing one guitar preamp or just one Aux send, ( here only One green Led will light up on the left screen of my H8000)
            it sounds slightly different compared when it is feed from stereo (Preamp Out + Aux Send simultaneously ) ,I don't know why.
            So, my question is: which is the best way to feed a Summed In preset ? should I feed it with Mono or with Stereo source?
            Let me know,
            Thanks
          • #135150
              Dario:
              My answer has to be that it depends on which sound you want. I would probably go on balance for the stereo option, because this will work better with true stereo presets.
