Routin tool/software not interfacing between PC and H8000FW
Home Forums Products Rackmount Routin tool/software not interfacing between PC and H8000FW
Viewing 3 reply threads
    • #105985
      Hi folks,
      I'm trying in several manners to handle the routing tool from my PC but no success.
      I tryed several manners:
      – via midi by a sound card
      – via FIREWIRE / midi via DICE drivers (they works perfectly as sound card so are good
      installed)
      – the above have benn done by 2 different PC,s but no success
      – I have NOT tried via a serial cable as I do not have serial connection on PC
      It is evident that I am unable to have a coonection between the Routing software and the H8000FW; it remains solidly in "DEMO MODE"
      Can somebody give me some suggestions or "tricks" to have success in this?
      Many Thanks
      Emilio Biagini
      Lucca — Italy
    • #118150
      IDeangelis
       Ciao Emilio
      you should get one of those USB_to_Serial port converters. I have a couple of them and work fine on both Windows and Macs.
      best
      Italo
    • #118151
      Italo,
      I have tested, now it works!
      Very useful tool!!
       Thanks a lot
       Emilio
    • #129237
      IDeangelis
       Good!
      It should be pointed out that many PC motherboards may not offer a COM port…BUT most of them have a socket on whick a COM port PCI bracket can be connected.
      This is true of all motherboards I have used, ASUS that is. I'm sure other brands may have similar configurations.
      regards
      I
