Home › Forums › Products › Rackmount › Routing 2.8 and firewire
hi,
thanks for the routing program.
Can the Routing program can connect to H8000fw via the firewire connection ?
Glad you like it !!
You should be able to select and use a FireWire MIDI channel. This works better in V5.5 than in earlier versions.
