Routing: multiple inputs to the same processing path
Home Forums Products Stompboxes Routing: multiple inputs to the same processing path
Viewing 5 reply threads
    • #181161
      unguitar
      does anyone know if it’s possible to have all 4 inputs routed to the same path (not in parallel)?
      It would need the inputs to be summed.
      thank you
    • #181202
      You can use Insert routing to use the H90 as a mixer. You can watch this tutorial for more information: https://youtu.be/0G_WtfUatSc?si=DXefUjr4-4XaXIW7&t=1190
      You can turn Force Mono on and this will make output 1-2 a dual mono pair with the same signal on both outputs.
    • #181234
      unguitar
      thank you, this is dependent on the algorithm right?
      Is it possible to make it a default global setting?
    • #181239
    • #181245
      unguitar
      sorry, it’s probably because English isn’t my mother language, let me reformulate:
      is it possible to have insert ALWAYS patched as default or is it just dependent on how you saved each single program?
      • #181247
        No, that is not possible. You will need to save each Program with the desired insert routing.
    • #181251
      unguitar
      ok, this is what it looked like. Thank you for the final confirmation
