Routing of H90 with GT1000CORE
Home › Forums › Products › Stompboxes › Routing of H90 with GT1000CORE
    • #174105
      williamsnrb
        <p style=”text-align: left;”>Hi!</p>
        I had the H90 and Tonex, but I need headphone output and couldn’t get it when paired with the H90 in stereo. So, I’m going to try the H90 with my GT1000CORE instead. I have my drives up front and then a Polymoon delay, H90, and GT1000CORE. How would y’all route those three pedals to optimize options in stereo and retain full headphone capabilities if the GT1000CORE? Thanks!
      • #174111
        williamsnrb
          Just to follow up: I went with the drives into the H90 -> Polymoon -> GT1000CORE In -> 4CM back to the H90 -> 4CM back to the GT1000CORE -> Out. It sounds spectacular so far, but I’m going to have to rebuild patches to include the loops. Maybe that will help anyone in a similar situation in the future. Take care!
        • #194771
          cestlamort
            I’m trying out a similar set up (albeit very pared down for a fly / train rig): H90 + GT1000Core in some configuration. Currently, I have the H90 in the stereo loop of the GT1000Core, but would like to explore different routing options (especially with the H90 being so flexible with routing) beyond the current [some stuff in the GT1000Core through the amp models and maybe a bit more] > [H90 algorithm 1] [H90 algorithm 2] > [GT1000Core effects after amp models]
            A couple questions with your pictured routing:
            Did you run stereo throughout: from H90 > GT1000Core > H90 > GT1000Core?
            Your photo seems to have H90 (mono) > GT1000Core (mono) and then stereo from there. (I ask because one of my frustrations with the GT1000Core is that it tends to want to sum to mono for the amps).
            Thanks for any insight. I’d hoped this would be a small and powerful set up (it is, I think) but I’m still getting my head around multiple layers of effects loops and routing.
