Routing Questions for H90
Home › Forums › Products › Stompboxes › Routing Questions for H90
Viewing 3 reply threads
    • #167392
      sumpe13
        Routing question for Dual Routing:
        – Would it be possible to run Path 1 with DSP+Fx and Kill-Dry, but Path 2 without Kill-Dry *and change these around per Program/Preset within a Playlist (so long I keep the Dual Routing for that list, of course)?
        In other words, something like the H9 where one can change Kill Dry status per Preset, and override what the Global Setting is, but in this case, what I really need to know is if running Dual Routing one can override the Global Kill-Dry setting per Path as I would be using both at the same time but each Path with a Preset, in a way Parallel/Independent of each other??
        Thank you –
      • #167393
        joecozzi
          Yes. Keep in mind, the H90 no longer has a DSP+FX mode like the H9 because you have spillover automatically. You also get a Tails control that controls what happens when the Preset is bypassed (like DSP+FX).
          …and change these around per Program/Preset within a Playlist (so long I keep the Dual Routing for that list, of course)?
          Yes. Kill Dry can be set at the Preset or Global level and a preset can defeat the global setting.
          Yes, as explained Kill dry can be set at the Preset, Program, or Global level.
        • #167506
          sumpe13
            Hey. Thank you so much for the support.
            A follow-up question as I try to brainstorm how I would set up the H90 – would it be possible to set Kill Dry also for individual paths on a Parallel or Series Routing for Insert Mode? Thanks
          • #167507
            joecozzi
              Since Kill dry can be activated on an individual algorithm, yes.
