August 23, 2011 at 7:05 pm #108077
robert
ParticipantHey all,
downloaded the new Routing Utility application for OSX, but can't get it connected with the machine (h8kfw) over MIDI (the only option on OSX). Tested the MIDI ports in Ableton Live and they look fine. What I do see in the MIDI ports pick list that a couple of port names are duplicated.
Did any of you get it working on OSX?
Cheers,
Robert -
September 23, 2011 at 3:29 pm #122686
mjmundy
Participantrobert, i have the routing utility working on OS X snow leopard, via firewire. i haven't tried it any other way.
-mike
September 23, 2011 at 3:33 pm #122687
mjmundy
Participanti have the routing utility working on OSX snow leopard over firewire. haven't tried it with MIDI.
-mike
September 24, 2011 at 4:17 am #122688
mjmundy
Participantas an update – i had to setup a mac book pro (snow leopard) in place of my usual system and figure this out from scratch. i have the hardware connected via firewire; no MIDI cabling. basically took these steps:
- installed the eventide h8000fw software driver & rebooted.
- confirmed that eventide DICE loads and shows up as a MIDI device in OSX audio/midi setup utility.
- ran the eventide routing utility, selected the H8000FW device under operations menu
- in the comms config, selected the eventide dice port 1.
- finally, clicked on the "off line demo mode" under operations, which was "checked", then became unchecked and the utility connected to the H8000FW. perhaps this is the not so obvious step!
good luck
-mike
September 24, 2011 at 6:42 am #122689
robert
ParticipantHi Mike,
that's great news. Could you explain in more detail how you got it working? I have the same setup (Snow Leopard, FW link) and no success.
Maybe you are referring to the MIDI port that comes along with the FW Dice driver? Tried that, but Routing Utility stays in offline mode.
Cheers,
Robert
September 24, 2011 at 9:14 am #133836
robert
ParticipantThat last step indeed fixed the problem!
Geesh, never thought about it to uncheck it, it looked like an indicator, not a switch, lol.
Thanks Mike!
