March 2, 2009 at 1:28 am #106088
What's the latest? I'm getting to the point where I could really use that thing. Also, is it going to work in Logic Pro 8? I know you had mentioned proTools, but I switch from ProTools to Logic. As long as it's a RTAS native, it should be seen in Logic, but are you expressly testing?
March 2, 2009 at 9:20 pm #118347
Sorry, it's still running late.
RTAS is a Protools format and will not run as-is on Logic. There are various "wrappers" that can allow an RTAS plug to run under VST or AU, but it might be difficult for us to support them.
March 3, 2009 at 1:34 am #118350
OK, it's never gonna happen for me then. I don't understand why you started marketing it with what looked like finished screen shots almost 15 months ago.
I found another way to work which doesn't require the plug-in so I don't care anymore. Plus I switched to Logic, so based on your response, I will forget about the whole thing.
Maybe others will be luckier… -
March 11, 2009 at 7:26 am #118385
Nick,
Just to clarify. The opposite is true. There various VST to RTAS wrappers but not RTAS to VST or AU.
David
March 11, 2009 at 4:24 pm #129486
Hi David
Thanks for the clarification:
"Confusion, will be my epitaph" etc.
