S/PDIF 3&4 – SRC not working.
Home › Forums › Products › Rackmount › S/PDIF 3&4 – SRC not working.
    • #106151
      Sonic Nomad
        S/PDIF 3&4 causes broken and garbled signal when using a different sample rate to the H8000. The same signal on S/PDIF 1&2 is fine. Setting SRC Mode on/off makes no difference.
        This is usually when the H8000 has an internal clock rate of 48k and the incoming signal is 44.1k. When both are at 44.1k both S/PDIF 1&2 and ?&4 sound fine.
        Would like to make use of S/PDIF 3&4 in with it's ability to route directly to Firewire Outs. Using S/PDIF 1&2 nows uses up a main I/O.
      • #118467
          Sorry – S/PDIF 3&4 do not have sample rate conversion.
          The only inputs with sample rate conversion are AES1-4, and hence S/PDIF 1&2.
