Home › Forums › Products › Vsig and Preset Development › Sampler Looping/crackle Problem
September 7, 2010 at 3:27 pm #107256
MFPhouse
Participanthi folks,
i build a Looper with Vsig.Everything works fine exept:
when the loop is made it´s played with an Crackle at the loop_end. If the Loop is fresh created.
I figured out it has nothing do to with Xfade parameter
It´s just the "start" parameter wich has to move a few ms seconds ( forward ). After that the crackle is away and all other Parameter works fine.
So , what to do ( programmed ) ? to get the loop direktly without an Crackle.
I just want to press the "record" and after finishing the Phrase i press the "Play" button, so the Recording play immediately direcly in the Loop…..without a crackle .
Thanks
September 21, 2010 at 8:59 am #120767
ThreeFingersOfLove
ParticipantMaybe you could insert an adjustable gate with threshold, so that when the crackle appears, the gate opens and it suppresses it?
September 22, 2010 at 11:42 am #120776
MFPhouse
ParticipantI tryed it today. But it did`nt changed anything.
But it was very interesting , because a found something new out !
I made the "gate" Modul direct after the Input and than to the Sampler-Modul.
( Sampler rec in )…and close the gate 0 db ( Signal didn´t reach Threshold at all ) Close.
The "crackle" came definitely from the Sampler-Modul .
I recorded this crackle also . It ´s 36ms long ! no matter what kind auf Audio-Signal came in.
Means also Softed Attack Audio Material !. And it´s alltime the same.
I think it´s the "Trigger-Prozess" from/in the Sampler-Modul itself.
January 2, 2011 at 1:00 am #132430
tomylee
Participanthi there, I also played with the sampler module, try to trigger the sampler with shorter impulses, that made the crackes disappear in my case, though I had a different preset setup as you, I was trying to trigger the sampler into audio range, that worked well with a bit of tuning, unfortunately the start time parameter is control not audio or mod domain, so I was not able to build a wavetable synth with my beloved h8000 😉
January 29, 2011 at 11:22 am #132689
MFPhouse
Participant…mhhh. Now i still build it with a simple Delay Modul.
The crackle is much smaller but anyway out of control.
Now i am thinking about to build Crossfade modul .
Anybody ideas ?
