Save different global settings in different playlists?
Home Forums Products Stompboxes Save different global settings in different playlists?
    • #174239
      Nitrofunk
      Hi! I’m planning to get the H90 for two different bands: As a keyboardist in one band (with two monosynths plugged into the H90 at the same time) and as a bass player in the other (just one bass plugged into the H90 – no other instruments). Since I don’t want to calibrate the input levels every time I change the instrument: Can I permanently create one playlist for the bass- and one list for the synth-band, each with correct input-settings? In other words: Can I save those input settings in a playlist or do I have to readjust them every time in the globals-menu?
      Peter
    • #174240
      joecozzi
      Operating levels are global, so they need to be adjusted in the System menu. They are not stored on a Playlist basis. Regardless, switching operating levels takes the same amount of time as switching Playlists. It’s easy.
