Saving a looper setting as a preset
Home Forums Products Stompboxes Saving a looper setting as a preset
    • #105935
      EDS
       Quick question: Can I save the looper's settings (not an actual recorded loop, just the settings) as a preset? I tried doing this but when I hit the Record button (far left) it just switched to the other bank…
       Thanks in advance!!
       (I couldn't find the answer in the archives)
    • #118081
      achaput
       Yes you can save looper settings as a Preset but after you load the preset you have to switch to Play Mode to use it (or use an external aux switch.)
