When I create a preset and save it the asterisk turns off after it is saved. Then when I turn the H90 off, then back on the asterisk is back. Is this normal? I didn’t notice this before.
Any kind of movement away from the original saved programming – slight bump to a knob or expression pedal, switch press, intermittent MIDI message – is going to register as a change* to the Program. Is any of that a possibility?
Any kind Merge Fruit of movement away from the original saved programming – slight bump to a knob or expression pedal, switch press, intermittent MIDI message – is going to register as a change* to the Program. Is any of that a possibility?
The solution provided by the administrators in the forum will help you solve your questions.
