Saving Delay Times In TimeFactor
Home Forums Products Stompboxes Saving Delay Times In TimeFactor
Viewing 5 reply threads
    • #106172
      Would appreciate any help with this
      I can't seem to save a new delay time in a preset. Whether it's tapped in or adjusted with the encoder, I save it and leave the preset and when I come back to the preset it is always a different time. I've gone to global and set the mix & the tempo to off and tried, I've set it to on and tried, still when I save a new time it's diff when I recall the preset. I have the latest software 2.0. Any suggestions???
      thx
    • #118492
      Is this because of your knob-mode? Surprise
      You can set it for immediate or catch-up (check the manual).
    • #118493
      No it's not because of that. In global I have mix set to off and tempo set to off. I've tried catch up both ways and it's no diff.
    • #129661
      luca9583
        Hi idealguitars
        I get a similar problem. I have a midi setup. Each of my Timefactor presets are saved with their own delay time. When i select my first preset, it never comes up with the correctly saved delay time..but if i then select, for example, my second preset, and then go back to the first preset, the first preset now comes on with the correct delay time.
         I will try using the catchup function but this shouldn't affect a delay time that has actually been saved, as opposed to it being tweeked on the fly,
      • #129800
        thom
          Luca9583 is describing exactly the issue I have with my Timefactor when saving settings. I described this in a different thread.
          Luca, did you ever resolve this or just live with it?
        • #129802
          luca9583
             Hi Thom
             It seems that this is a glitch in the Timefactor which would need to be resolved in a future update.
             I live with the problem at the moment by selecting, for example, preset 2 and then go back to preset 1 and preset 1 is back to the correct saved delay time.
             Catchup does not solve the issue
