Home › Forums › Products › Stompboxes › Saving Presets 2 List on iPhone
September 10, 2013 at 3:32 am #111079
DaGuy
ParticipantHi,
First, the H9 + iOS software is ground breaking. So far I'm stomped on how to save presets to a list on the iphone version of the software. It's real clear how to do this on an iPad but the iPhone lacks screen real estate so I don't see how to do this. Help appreciated. Thanks.
September 10, 2013 at 1:58 pm #124777
gkellum
ParticipantWell, this will work a little differently depending on whether you're editing a preset list that is saved locally on your iPhone or the preset list that is on your stompbox. In the first screen for preset lists, what's selected in the source column determines which one of those you're looking at. I'm going to describe the case of editing a local list and transferring it to a H9, and hopefully, that will help you even if that's not exactly what you're doing.
When you're in the lists screen and looking at the representation of the preset list with 99 buttons, i.e. one button for every preset, to assign a preset to a position that already has a preset, you need to click on the button twice; the first time you click on the button it will load the preset and when you click on the button again, it will take you to the preset selector screen. At the top of the 99 button screen is a save button which will save your changes to the list locally on your iPhone. To transfer your edited preset list to an H9, you need to click the back button to go to the opening preset list screen which shows an overview of all of the lists. Clicking on the "To Pedal" button on the top of the screen will send the preset list over to your connected H9.
September 11, 2013 at 4:06 am #124782
DaGuy
ParticipantGreat, thanks so much! I Because of you instructions, if just figured I was not using the BACK button after selecting/loading the preset. It now works great!!
I've had a bunch multi-effects and pedals over the years and I thought nothing could get my blood flowing but this H9 thing totally does! The software is really done right!
September 11, 2013 at 4:06 pm #135602
gkellum
ParticipantI'm glad to hear that you've been having a good time using H9 Control.
We'll probably change the behavior of the save button in a future release so that it asks you whether you want to save your changes to the local harddrive or a connected H9. That would prevent this sort of confusion and would be consistent with the way that the save button works in the preset screen.
