Home › Forums › Products › Stompboxes › Saving the mix level on the Space
September 29, 2015 at 8:45 am #112892
blackvomit
MemberDoes any one know how to save the mix level for a preset I’ve made on the space? I can’t figure it out for the life of me
September 29, 2015 at 3:24 pm #140766
Please refer to the Space User Guide: https://www.eventideaudio.com/support/downloads/space-user-guide
Saving Presets To save a Preset:
1) Press and hold the Encoder for a few seconds. The current Preset# and 10 characters of the Preset Name are displayed. Release the Encoder. The “Edited” LED flashes. The Preset # flashes if it is NOT the currently loaded Preset. If the currently loaded Preset # is displayed, it is solidly lit.
2) Turn the Encoder to select the desired Preset#. The “Edited” LED flashes when the currently displayed Preset# is not the active Preset#. When saving, all Preset numbers are available even if you’ve limited the number of active Presets.
3) Press the Right Footswitch and the first character of the Preset name will flash. Turning the Encoder will change this character. Preset names can have up to 16 characters. (The available character set is '0-9', 'A-Z', '*’, ‘+’, ‘-‘,’_’, and ’|’.)
4) Use the Left and Right Footswitches to traverse the display, selecting the character to be edited by the Encoder. (The active character for editing is always flashing.) Repeated pressing of the Right or Left Footswitch will traverse the name, one character at a time, flashing the selected character. Press and hold Left Footswitch to DELETE the current flashing character.
5) Press and hold Right Footswitch to INSERT a character before the currently flashing character.
6) To save the Preset, press and hold the Encoder a second time. The Billboard displays “SAVED.”
7) After a short time, the Save mode is exited.
8) To exit Save without saving, press and release the Encoder again without holding it or press any Footswitch at any time. Upon exiting Save mode without saving, the Billboard displays “NO SAVE.”
Note: You must press and HOLD the Encoder to save. If you press and release quickly, the new Preset will not be saved. This is intentional. When you save a new Preset, you overwrite the old Preset. is designed to assure that saving is a deliberate act. The Preset number corresponding to the currently running Preset will flash as a warning that saving in this location will overwrite the currently loaded Preset.
Note: Name changes affect the current Preset even if NOT Saved. This feature allows you to rename a Preset without changing any of the Parameter values.
September 29, 2015 at 4:22 pm #140767
blackvomit
MemberI understand how to save a preset. After saving a preset, the mix level seems to be universal. I was wondering if it was possible to have a set mix level for a preset
September 29, 2015 at 5:44 pm #140772
gkellum
Participantblackvomit wrote:I understand how to save a preset. After saving a preset, the mix level seems to be universal. I was wondering if it was possible to have a set mix level for a presetThe mix level is only universal if you have the Global Mix setting enabled; if you want to use the mix level saved with the preset, you'll want to turn that setting off.
September 30, 2015 at 4:13 am #140787
blackvomit
Membergkellum wrote:blackvomit wrote:I understand how to save a preset. After saving a preset, the mix level seems to be universal. I was wondering if it was possible to have a set mix level for a presetThe mix level is only universal if you have the Global Mix setting enabled; if you want to use the mix level saved with the preset, you'll want to turn that setting off.
Even with “global” set to off the mix level still seems to be universal
September 30, 2015 at 1:53 pm #140790
gkellum
ParticipantHm… Do you have an expression pedal or MIDI controller hooked up to your Space?
Could you try disconnecting anything of that nature that might be connected to your Space and saving a preset as described above, changing the preset, going back to your saved preset, and seeing if it has the mix level that you saved?
