January 11, 2011 at 9:53 pm #107552bazsa82Participant
Can I do it: I play C major scale and the eclipse sustain a C note?
Bazsa82
January 12, 2011 at 4:14 pm #121384
I can't answer this – I'll ask around.
January 17, 2011 at 1:22 am #121425bazsa82Participant
And the eclipse play an harmony, when I play notes? For exaple C major scale, the eclipse sustain
c e g?
Thakns!
Bazs82
May 17, 2011 at 10:08 pm #122135bazsa82Participant
Sorry, Can you help me?
1.So the eclipse can hold a note, when I play with them?
2. Can I set the user scale? For example I make my special scale:
c d eb f f# g a b c'
May 17, 2011 at 10:41 pm #133416achaputModerator
You can definitely create custom user scales with Eclipse.
Holding notes is possible as well. You would have to assign a controller to send delay feedback too 100% after playing the note.
May 17, 2011 at 10:43 pm #133417
Hi Bazsa82,
Yes, the eclipse supports user scales. This works by setting a shift amount (in cents) to each of the notes in a 12 tone scale, c through b. So if you set the shift amounts up like this:
[0, -100, -200, -300, -400, -500, -600, -700, -800, -900, -1000, -1100] the output will always be a c, no matter what you play.
Dan
May 19, 2011 at 8:39 am #133436bazsa82Participant
Thanks, I will try it.
May 20, 2011 at 7:07 pm #133442bazsa82Participant
I try it, but I don't chose the userscale. Only major, minor….
Balage
May 31, 2011 at 9:51 pm #1334612oldmanMember
Perhaps a patch like Ether Harp is what you seek.. play one note, it plays more…
