Seeking Neck Pickup Sound
Home Forums Products Rackmount Seeking Neck Pickup Sound
    • #182914
      gustebeast
        My guitar only has a bridge pickup but I prefer the warmth and richness of a neck pickup for jazzy neosoul stuff. I have been using “Guitar/Warmer Acoustic” to try and emulate the neck pickup sound with decent success, but I’m curious if there’s a better option.
        I’m also interested in adding some light compression to my signal so if there is an algorithm that could do this warming AND compression in one that would be ideal.
        Any suggestions?
        – Gus
      • #182916
        gustebeast
          Forgot to mention this is for the H9K
        • #182924
            It sounds like you are using some of the EQ45/EQ65 presets. These algorithms have an alternative version called “ST Compress > EQ45/EQ65” which adds a pre EQ compressor.
            You could also try the EQ Compress algorithm from the H9. The Leo to Les or JazGuitar presets might work for your setup.
