Home › Forums › Products › Stompboxes › Selecting TOG/BYP/ACT problem MidiMapping
September 24, 2010 at 3:41 pm #107280blowbackMember
Setting up my PF to work in bank mode.The first patch change I was able to set to Bypass but the second patch change just scrolls through PF preset #'s on the right side of the screen and doesn't allow me to select the state of the patch change.I'm following the instructions in the manual,any ideas??? I'm guessing that since I didn't map the first preset,just bypassed it and am trying to map the second preset this is causing a problem ????
September 24, 2010 at 4:16 pm #120778achaputModerator
I need a little more information. as some things are not clear from what you wrote. Are you using a MIDI controller to select patches on the PitchFactor? If so, which MIDI controller?
Exactly what functionality are you trying to achieve? Please describe in detail.
-Alan
September 24, 2010 at 7:01 pm #120780blowbackMember
Yup,I'm using a Rocktron MidiMate as a midi controller.
Basically I want to be able to toggle the selected effect on and off but I couldn't get the Pitchfactor to display the Toggle,Bypass,Active menu at all even with the flashing arrow pointing the right direction turning the encoder button counter-clockwise as the manual says.
All it would do is scroll through the various bank number presets for mapping,which I had already mapped to the specific preset.I was able to set the first preset to Bypass no problem,the encoder button worked fine going counterclockwise.But I didn't map a preset to the first one I did,just bypassed it.When I set the second preset I needed to map an effect to the button and I can map the effect but can't access the BY/TOG/ACT function at all
Any ideas???
September 25, 2010 at 4:19 pm #131992cavemanParticipant
When I read that section of the manual, it seemed to me that a mapped program change EITHER loaded a preset (whether bypassed or not) OR did the bypass/toggle/active function without actually loading a preset.. Either way, clarification from eventide would be appreciated.
September 26, 2010 at 6:49 am #131994blowbackMember
Well I guess I can just assign my first preset in the bank to bypass the pedal for my un-effected main rhythm tone and just hit that switch every time w/ my foot but man is that gonna be a pain in the booty to assign a bypass switch in every bank on my Midimate
Not to mention my amp head is midi switchable and I was planning on having at least 3 or 4 distorted rhythm/lead sounds or maybe I'll just arrange the banks by effects needed for songs by their set list order.
September 28, 2010 at 3:46 pm #132006achaputModerator
The other way to select Bypass using MIDI is with MIDI Continuous Controller.
From PitchFactor's MIDI/RCV CTL menu you can select which MIDI CC will operate BYPASS.
After you choose a MIDI CC number for this, you should be able to set a button on the MIDImate to transmit that same MIDI CC and bypass the PitchFactor that way.
-Alan
