send MIDI command when switching to preset
Home Forums Products Stompboxes send MIDI command when switching to preset
    • #182155
      lp69
        Hi, I can’t find how to do a very basic MIDI operation : I need to switch my amp to the clean or drive channel depending on the preset I activate on the H90.
        My amp features a MIDI IN command to select the channel.
        How do I send a MIDI command per preset ?
      • #182357
          Loading any Program from the Program list will send a PC message. Example: Load Program 10 on the H90 and it will send PC 10.
          Connect the H90’s MIDI output to the amp’s MIDI input. On the H90, set Output Mode to Transmit in the MIDI menu, and you should also set PC offset to 1 so the numbers match up. You also need to make sure both devices are using the same MIDI channel.
          https://cdn.eventideaudio.com/manuals/h90/1.7.5/content/system-menu/midi.html
          Let me know if that works.
        • #182363
          lp69
            Ah I didn’t know, that should fit my purpose.
            Thank you very much !
            • #182366
                You’re welcome!
