Sending CC messages using h9 aux switch
Home Forums Products Stompboxes Sending CC messages using h9 aux switch
Viewing 5 reply threads
    • #111465
      siggy76
       i am trying to configure my H9 to send a CC control to activate a loop on an external midi machine as stated on page 32 of the user manual. Also I've enabled the XMIT CC and activated the midi out.
      As a result when I press the aux switch that I've programmed to send cc85, the h9 doesn't transmit nothing…
      Someone could Help me?
      the external midi machine works well with my TC g-system, and it accepts CC messages from 85 to 92 on channel 1
    • #125565
      Make sure that:
      CTL.XMT is set to ON
      EXPTIP is set to SWITCH
    • #125567
      siggy76
      Already checked…
    • #136294
      No obvious answer, I'm afraid. It works fine for me.
      There is a new software version due shortly – give that a try. But, it could be something at your end.
    • #136298
      siggy76
      I've swapped how the units are connected and now it works. Now the problem is that the h9 doesn't merge the Cc messages from other units when the output is set to XMIT but only in thru mode…but in this mode no Cc from the H9 are transimetted.
    • #136299
      The H9 does not claim to have a merge input. I'm not aware of any pedals that do (a thousand people will now prove me wrong). Sorry.
      You may want to consider a MIDI merge unit from someone like MIDI solutions.
