Sending CC with the H9
Home Forums Products Stompboxes Sending CC with the H9
Viewing 6 reply threads
    • #113466
      dafonk
      Is it posible to send MIDI CC with the H9 ?
      Let say the left footswitch send CC60 and the Right footswitch send CC70.
      Thank you for your help.
    • #143425
      It is possible, but not from the footswitches (this is because they have major functions, and we think it would be confusing). See the UM for details.
    • #143426
      dafonk
      I tried using an digitech FS3x but it didn’t work.
      • #143428
        dafonk wrote:
        I tried using an digitech FS3x but it didn't work.
        You should be able to use an AUX switch to send MIDI CC. Look at "XMT CC" in the UM.
      • #143430
        dafonk
        nickrose wrote:
        You should be able to use an AUX switch to send MIDI CC. Look at “XMT CC” in the UM.
        I’ll try again.
        I want to send CC from my aux switch (FS3X) to the MIDI of the H9.
        It should be possible ?
    • #143433
      I'm confused. Is your switch plugged into the H9 ? It sounds like you want to use it to send CC to itself.
      • #143436
        dafonk
        nickrose wrote:
        I’m confused. Is your switch plugged into the H9 ? It sounds like you want to use it to send CC to itself.
        Sorry I meant the MIDI OUT of the H9.
    • #143435
      dafonk
      No, I want to use the H9 as a translator if it’s possible.
    • #143439
      In that case you should be able to do it.
      As mentioned earlier, please look at "XMT CC" in the UM.
      It's fairly straightforward.
    • #143440
      dafonk
      What MIDI OUT mode should I use ?
      XMT, THRU, MERGE ?
      Thank you
      • #143442
        XMT, THRU, MERGE ?
        Normally you would use XMT, unless you also want to pass MIDI through the H9, when you would use MERGE. Don't use THRU, as this will prevent the H9 from sending your AUX switch CCs.
