Home › Forums › Products › Stompboxes › Sending midi
- This topic has 4 replies, 2 voices, and was last updated 1 year, 4 months ago by
kingbee.
November 9, 2023 at 7:07 pm #175571
kingbee
ParticipantIs there a way to send midi to Two Notes OPUS from H90 and aux switch to change presets on OPUS?
November 9, 2023 at 8:45 pm #175573
Hi kingbee,
Yes, this is possible. This can be configured in the System Menu’s MIDI section. When the Output mode is set to Transmit, any program changes can be sent to downstream devices connected to the MIDI out. It is also possible to program an aux switch to send program search commands as well. All answers can be found in this video beginning at 8:38: https://youtu.be/tfd3wQHzxcA?si=HXvDX_JL55d578_c
November 9, 2023 at 10:39 pm #175575
kingbee
Participantcc number 68 selects preset on Opus. At this point the aux button when held down selects end of range (99) and when let go, goes back to beginning of range (01). How do I assign a cc value to choose the actual preset in the Opus?
November 9, 2023 at 11:52 pm #175576
I would not use CC numbers to change presets. It’s better to use PC numbers, as it states in the Opus manual on section 5. MIDI. The way things would work is you load a preset on the H90, let’s say preset 10, then the H90 sends PC#10 to the Opus. Ideally, you would Program presets on the Opus to match up with the loaded H90 preset.
If you prefer to jump around, for example, have Preset 10 loaded on the H90 but use preset 97 on the Opus, it’s better to use a MIDI controller that transmits to each pedal on its own MIDI channel, since the H90 only sends the PC# for the Program that it’s on.
With regards to using the aux switch, in the MIDI section of the System menu you have the “MIDI – Global Control” where you can assign a switch to control functions such as increment, increment + load, decrement, decrement+load, and simply load. So as you press the aux switches it will change Programs on the H90, which in turn will change presets on the Opus. You can’t program an aux switch to go to a specific Program, if that’s what you’re trying to do.
The other option is programming the aux switches to transmit a CC# to the Opus, but you have to program that CC# in the “Pedal – Transmit” section of the MIDI menu. So, if you say CC#68 selects preset in the Opus, then you can map a switch to always send CC#68. But again, it’s not typical for CC messages to be used to recall specific presets. That’s what PC#s are for.
November 10, 2023 at 7:49 am #175577
kingbee
ParticipantGot it. Thanks.
