June 27, 2018 at 7:18 pm #114807
mikeyx13
ParticipantI have been pounding my head trying to send presets vis MIDI to my Eclipse. They came is .syx format, I’m on Win10, tried on a laptop and a desktop, using MIDI-Ox through a Roland UM-One , also tried through a Steinberg UR22.
I load the file in MIDI-Ox, select send syx, monitor shows the data pass. Nothing changes on the Eclipse, ver 4.01. If I press a number button on the Eclipse it sends data to MIDI-Ox. I have the Eclipse set to a program number 001, program change is enabled
What am I missing?
June 27, 2018 at 7:21 pm #149577
Not clear what's in your .SYX presets – they may well not be what Eclipse expects.
Can you send a hex dump of one of them ?
June 27, 2018 at 7:41 pm #149578
mikeyx13
ParticipantHere’s an example of one of the syx files I’m sending
Opened MIDI Input
Opened MIDI Output
000075B7 MOX 17 F0 Buffer: 256 Bytes System Exclusive
SYSX: F0 1C 70 01 36 35 33 32 20 34 2E 30 31 20 20 0D 0A 32
SYSX: 78 32 32 39 30 73 0D 0A 31 33 36 0D 0A 33 0D 0A 30 0D
SYSX: 0A 31 31 38 20 20 0D 0A 31 30 30 0D 0A 31 30 30 0D 0A
SYSX: 30 2E 30 30 30 30 30 30 0D 0A 30 2E 30 30 30 30 30 30
SYSX: 0D 0A 31 31 32 20 20 0D 0A 35 30 0D 0A 35 30 0D 0A 30
SYSX: 2E 30 30 30 30 30 30 0D 0A 30 2E 30 30 30 30 30 30 0D
SYSX: 0A 37 0D 0A 66 62 31 3D 34 30 2E 30 30 30 30 0D 0A 66
SYSX: 62 32 3D 32 35 2E 30 30 30 30 0D 0A 64 6C 79 32 3D 38
SYSX: 39 39 2E 39 37 38 36 0D 0A 74 68 72 65 73 68 3D 2D 35
SYSX: 33 2E 30 30 30 30 0D 0A 72 61 74 69 6F 3D 38 2E 30 30
SYSX: 30 30 0D 0A 61 74 74 61 63 6B 3D 30 2E 30 32 30 32 0D
SYSX: 0A 64 65 63 61 79 3D 30 2E 35 30 30 30 0D 0A 32 39 0D
SYSX: 0A 64 6C 79 5F 31 3D 32 37 0D 0A 64 6C 79 5F 32 3D 32
SYSX: 37 0D 0A 64 6C 79 5F 33 3D 32 37 0D 0A 64 6C 79 5F 34
SYSX: 3D 32 37 0D
000075F8 MOX 17 F0 Buffer: 256 Bytes System Exclusive
SYSX: 0A 64 6C 79 5F 6D 3D 30 2E 30 30 30 30 0D 0A 64 6C 79
SYSX: 31 3D 31 32 2E 30 30 30 30 0D 0A 64 6C 79 32 3D 32 34
SYSX: 2E 30 30 30 30 0D 0A 64 6C 79 33 3D 31 39 2E 30 30 30
SYSX: 30 0D 0A 64 6C 79 34 3D 31 35 2E 30 30 30 30 0D 0A 64
SYSX: 70 74 68 5F 6D 3D 36 35 2E 30 30 30 30 0D 0A 64 70 74
SYSX: 68 31 3D 38 2E 30 30 30 30 0D 0A 64 70 74 68 32 3D 38
SYSX: 2E 30 30 30 30 0D 0A 64 70 74 68 33 3D 38 2E 30 30 30
SYSX: 30 0D 0A 64 70 74 68 34 3D 38 2E 30 30 30 30 0D 0A 72
SYSX: 61 74 65 5F 6D 3D 35 30 2E 30 30 30 30 0D 0A 72 61 74
SYSX: 65 5F 31 3D 32 37 0D 0A 72 61 74 65 31 3D 30 2E 38 34
SYSX: 30 30 0D 0A 72 61 74 65 5F 32 3D 32 37 0D 0A 72 61 74
SYSX: 65 32 3D 30 2E 38 35 30 30 0D 0A 72 61 74 65 5F 33 3D
SYSX: 32 37 0D 0A 72 61 74 65 33 3D 31 2E 30 30 30 30 0D 0A
SYSX: 72 61 74 65 5F 34 3D 32 37 0D 0A 72 61 74 65 34 3D 30
SYSX: 2E 39 35 30
00007638 MOX 17 F0 Buffer: 256 Bytes System Exclusive
SYSX: 30 0D 0A 76 33 3D 30 2E 30 30 30 30 0D 0A 76 34 3D 30
SYSX: 2E 30 30 30 30 0D 0A 70 31 3D 2D 31 30 30 2E 30 30 30
SYSX: 30 0D 0A 70 32 3D 31 30 30 2E 30 30 30 30 0D 0A 70 33
SYSX: 3D 2D 31 30 30 2E 30 30 30 30 0D 0A 70 34 3D 31 30 30
SYSX: 2E 30 30 30 30 0D 0A 31 36 0D 0A 61 3A 74 68 72 65 73
SYSX: 68 0D 0A 61 3A 72 61 74 69 6F 0D 0A 61 3A 61 74 74 61
SYSX: 63 6B 0D 0A 61 3A 64 65 63 61 79 0D 0A 61 3A 64 6C 79
SYSX: 5F 31 0D 0A 61 3A 64 6C 79 5F 32 0D 0A 61 3A 66 62 31
SYSX: 0D 0A 61 3A 66 62 32 0D 0A 61 3A 76 20 64 6C 79 73 6C
SYSX: 65 76 0D 0A 62 3A 64 6C 79 5F 6D 20 6D 6F 64 5F 64 6C
SYSX: 79 73 0D 0A 62 3A 72 61 74 65 5F 6D 20 6D 6F 64 5F 72
SYSX: 61 74 65 0D 0A 62 3A 64 70 74 68 5F 6D 20 6D 6F 64 5F
SYSX: 64 65 70 74 68 0D 0A 30 78 34 30 30 33 30 31 31 30 20
SYSX: 6D 64 6C 79 73 4D 69 78 0D 0A 30 78 34 30 30 63 30 30
SYSX: 30 30 0D 0A
00007688 MOX 17 F0 Buffer: 64 Bytes System Exclusive
SYSX: 30 78 34 30 30 63 30 30 30 30 0D 0A 30 78 34 30 30 63
SYSX: 30 30 30 30 0D 0A 31 0D 0A 61 3A 73 65 6E 64 3D 2A 65
SYSX: 78 74 31 7C 43 30 2F 31 30 30 0D 0A 30 0D 0A 31 30 30
SYSX: 0D 0A 30 0D 0A 30 0D 0A 00 F7
June 28, 2018 at 12:58 pm #149582
mikeyx13
ParticipantSoooo, A very wise man from Italy said others had the same sort of issues with the Roland interface, I thought I had ruled that out using the UR22MkII. Two different Win10 computers, no luck. Remembered I had a Behringer UMC1820 in a box of unused equipment. Set it up, sent a file, worked first time out. Never had a problem with the Roland with any other equipment, it sure does not play nice with the Eclipse. Interesting that it didn’t like the Steinberg either. I hope this helps someone in the future, now to get back to playing!
