Home › Forums › Products › Stompboxes › Set Tap Tempo with External Pedal
January 11, 2010 at 8:02 pm #106773
flyingv2010
MemberHello Timefactor users,
Can anyone (maybe Eventide Crew?) tell me in a short summery how I can set a tap-temp with a external pedal. (must I connect it to the Aux Switch)
Thanks,
René
January 11, 2010 at 9:13 pm #119764
You can either use an Aux switch, or any suitable MIDI pedal. The User Manual will tell you how (under System Menu).
January 11, 2010 at 10:21 pm #119766
flyingv2010
MemberThanks for your reply, but I don't how to do it. In the manual is written that I first must press encode, but when I do that it's switching between tempo on and tempo out.
Is it possible that you make a short overview?
January 11, 2010 at 10:45 pm #130892
It really is all in the manual and it would be hard for me to add much that would be useful. Please study it carefully and rigorously – there is much useful information there.
In this, your problem is that you need to "press and hold the Encoder and Right Footswitch simultaneously for a few seconds to enter and exit the system mode."
January 11, 2010 at 11:46 pm #130894
flyingv2010
MemberThat was the problem. I didn't press and hold the encoder and right footswitch together. But if I take the option: TAP < TIP , the footswitch didn't take over taptempo, but activate and bypass the preset.
is it only possible to tap the tempo in play-mode or is it also possible in the bank-mode.
January 12, 2010 at 12:05 am #130896
flyingv2010:
It is possible to have multiple things connected to a footswitch – if you look at the other settings, you'll probably see that BYPASS is connected to TIP as well – this would explain what you see. The solution will be apparent.
flyingv2010:
If you use the external footswitch, it will be active in either mode.
