Home › Forums › Products › Stompboxes › Setting levels on multiple H9s
September 5, 2016 at 1:44 pm #113680
micklisa
ParticipantI have three H9 pedals on my board to take full advantage of the algorithms, but am confused with how to set input and output levels to optimize the signal and tone. I understand setting first pedal’s input to point below clipping but how to set output and other two H9 pedals. I am running these in series through the effects loop of my amp. Any insight is appreciated.
Mick
September 5, 2016 at 4:50 pm #144288
First approach would be to use the default values.
Do you have any reason (e.g. noise, distortion) to believe that these are not OK ?
September 5, 2016 at 5:47 pm #144289
micklisa
Participantnickrose wrote:First approach would be to use the default values.
Hi, yes the second and third H9 pedals have the red clip light showing more often than not. Do I fix this with input gain or output on the H9s? Or both?
September 5, 2016 at 5:49 pm #144290
micklisa
ParticipantClip light is red most of time on second and third H9 pedals. Do I fix this with input gain or output levels on H9 culprits?
September 5, 2016 at 5:57 pm #144291
It's not clear that you actually have a problem – if so, let well alone. A few red lights are OK – what does it sound like ?
Otherwise, I'm guessing you are probably over-driving the chain. The H9 expects a guitar level input – some effects loops give a hot line level, which is too high.
That said, there are a few things you can do.
1) If you are overdriving the first input, there is not much we can do (the H9 does not have an input attenuator). You could find a tech to make up a pad with a few 1c resistors.
2) But, it sound like the first unit might be OK, and it is that later ones that are peaking. In which case, turn down the main output levels. (latest revision required). Or, if the problem only occurs on certain presets, adjust their preset output gain.
September 6, 2016 at 3:02 pm #144293
micklisa
ParticipantThanks, how do you adjust main output volume in latest firmware? This is a global output setting?
September 6, 2016 at 6:49 pm #144305micklisa wrote:Thanks, how do you adjust main output volume in latest firmware? This is a global output setting?
Sorry – I am misinforming you. You can set main output level with a pedal (OUTSWELL) but not manually.
September 6, 2016 at 5:50 pm #144302
BMW-KTM
ParticipantAnalog or digital, I always set all pedals to unity unless they are being used as a boost.
