There are input gain parameters for the Program and each Preset. Depending on how you have your W/D/W rig setup, you should be able to map the expression pedal to one of those input gains to control the delay level.
You could also turn kill dry on for your delay algorithms, or for the entire program, and map the expression pedal to the mix knob and that will work in a similar way.
