Home › Forums › Products › Plug-Ins › Shift function in Blackhole
I miss a shift function in Blackhole like it is in Valhalla Shimmer. The the reverb is shifted up to an octave up and down. Any workaround?
Unfortunately, we don't have that in Blackhole. We do have our own Shimmer algorithm that does have it, maybe it would be a good addition.
Dan
Cubase 8 Pro does forget the Blackhole effect amount. This parameter is not saved in the project. Can you please fix this?
Hi Steril,
I think I may have to check this and get back to you. We may have to do a new Blackhole release.
Are you on Mac or Windows?
Hi Dan, I´m on windows 8.1 64bit. The rotary knop for “mix” is on the correct position, but the Mix amount is like in the init preset. You have to move the knop a little, than the mix amount is like shown again. Thanks, Axel!
Hi Axel (and everyone else reading this post),
This is fixed in the latest release of Blackhole (2.0.8) found here: https://www.eventideaudio.com/products/plugins/reverb/blackhole
