Shimmer plugin
Home Forums Products Plug-Ins Shimmer plugin
Viewing 13 reply threads
    • #114737
      wilkinsi
        I have a couple H9’s, but I really need Shimmer as a plugin. When are Eventide gonna do this?
      • #149213
        tlongabaugh
          I can't make any guarantees as to if/when, but we'll note your request.
        • #154501
          iszoloscope
            I would also kill for this! Well, not literally… but I would pay for it imediately.
          • #155458
            Jose7822
            • #155460
              tlongabaugh
                It took a couple years, but we made it happen 😉
              • #155465
                wilkinsi
                  THANK YOU, 🙂
                • #155466
                  modalmojo
                    How does the plugin compare to H9 hardware in terms of sound quality?
                  • #155470
                    wilkinsi
                      How do I convert and H9Z file into a .TIDE file? Can you make it possible for Shimmerverb to read both file types, please?
                    • #155487
                      wilkinsi
                        Here ya go. By the way, I’ve found that when altering the decay dial, it has a profound effect on how wet the plugin sounds, despite setting the MIX to 100% every time. I tried a piano track, and setting the DECAY to 0% makes it sound 50%. Setting the DECAY to 0% makes it sound very wet. Since there is no modulation dial, I am confused as to why the preset Vertigo Verge sounds as though its smoothly modulating up in pitch. What am I missing? I’m so confused now.
                      • #155488
                        wilkinsi
                          Oh, it bloody worked this time. I wonder if my Mac has bad RAM..
                        • #155494
                          wilkinsi
                            Correction to above – when I set to decay to 100%, it sounds 50$ wet. If I set the decay to 0%, then it sounds much wetter. Like I said, I am very confused.
                          • #155501
                            tlongabaugh
                              Hi-
                              Okay, the Decay issue you're experiencing – that's expected for the reverb and by design. It's a BH style reverb where Decay is increasingly pulling the whole signal through, and Size and Decay work together to create the total reverb decay time.
                              The Vertigo Verve modulating up is because the Pitch Shifters are set to 11c and 18c respectively – so each time they are fed back into the reverb, they will climb slightly.
                              Hope that helps.
                              -Tom
                            • #155514
                              wilkinsi
                                The sunlight and heat is killing me, but I’ll keep at it. I’ve already bought the plugin.
                              • #155767
                                Hey tlongabaugh,
                                Many thanks for the reply and clarification. I might try an in-place upgrade to 10.11 El Capitan, but first I need to upgrade to a larger disk 😉
                                Cheers,
                                Udo.
                              • #155467
                                tlongabaugh
                                  It should be near identical.
                                • #155472
                                  iszoloscope
                                  • #155735
                                    Thank you so much for making Simmer as a plugin! I bought it and was hoping to use it on my older MacBook Pro running OSX 10.6.8. I installed it correctly and authorised it with iLok, but it does not appear in any audio apps. I want to use it with Ableton Live 8.0.1, but have also tried Garage Band and Audacity. Tried refresh plugins, turn off/back on custom plugin folder, etc, whatever I could find on the web. It works fine on a newer MacBook running OSX 10.16.
                                    It would be great if you could help me get it working on OSX 10.6.8, or else confirm that it’s just not intended to.
                                    Many thanks in advance!
                                    Best wishes, Udo.
                                    Jose7822 wrote:
                                    Well, your wishes came true gentleman. No need to kill anyone either:
                                    https://store.eventideaudio.com/products/shimmerverb?variant=35462241616033&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&utm_campaign=gs-2018-12-10&utm_source=google&utm_medium=smart_campaign&gclid=EAIaIQobChMIgtSX_riB6wIVC9vACh3RIgzFEAQYAiABEgJt-_D_BwE
                                  • #155473
                                    wilkinsi
                                      Doesn’t quite sound 100% wet when I set it to that, compared to the hardware version. I should also add that I already tried importing .tide presets I made on the H9 into an insert instance, and it doesn’t work. Renaming .h9z files as .tide doesn’t help either. Please work on an update/fix for these issues. Thanks.
                                    • #155476
                                      tlongabaugh
                                        Could you take a screenshot or provide a preset of the settings where you aren't hearing 100% wet? Due to hardware differences, the pedal / plugin might sound slightly different, but I wouldn't expect the wet/dry mix to be affected.
                                        H9 Control should export .tide presets, if you export them one at a time using the "Export Preset" button in the Presets view of H9 Control. You can then load these through the "LOAD" button in the ShimmerVerb UI. Renaming the .h9z file to .tide won't work, unfortunately.
                                      • #155478
                                        wilkinsi
                                          tlongabaugh wrote:
                                          Could you take a screenshot or provide a preset of the settings where you aren’t hearing 100% wet? Due to hardware differences, the pedal / plugin might sound slightly different, but I wouldn’t expect the wet/dry mix to be affected.
                                          H9 Control should export .tide presets, if you export them one at a time using the “Export Preset” button in the Presets view of H9 Control. You can then load these through the “LOAD” button in the ShimmerVerb UI. Renaming the .h9z file to .tide won’t work, unfortunately.
                                          Sorry, please disregard my comment about the 100% wet sound. Not sure why, but it sounds correct now. I have since rebooted my Mac and interface a few times today.
                                          Unfortunately, I don’t have the H9’s anymore, so I can’t export those presets I have on disk again. When I try to load these user presets in Shimmerverb, the only thing that changes is the correct name. The parameters don’t change at all. I don’t get any error message.
                                        • #155479
                                          tlongabaugh
                                            Hm, that's odd – I'm able to import .tide presets saved from H9 Control into the ShimmerVerb plugin here. Can you post up the presets that are giving you problems?
                                          • #155742
                                            tlongabaugh
                                              Hey, unfortunately we only support macOS 10.9 and higher, so we can't offer support for 10.6.8.
