Home › Forums › Products › Vsig and Preset Development › .sif / .sig-format
February 8, 2011 at 10:06 pm #107630
razo
MemberHow does one convert an old file in .sif-format to .sig in VSIG 2.4.9 ?
Thanks Ole
February 8, 2011 at 11:18 pm #121543
Just load it into Vsig (File Open) and then Save As with the name ending as .sig
February 8, 2011 at 11:41 pm #121544
razo
MemberThats what I did first in the previous thread. The old .sif-file was still saved as .sif, not .sig…
regards
February 9, 2011 at 12:38 am #132723
In the save as dialog, are you sure you changed the filename to .sig ?
February 9, 2011 at 12:43 am #132724
razo
MemberI only see two options: '.sif/.sig' and 'all files'
February 9, 2011 at 12:44 am #132725
razo
MemberYes.
February 9, 2011 at 4:00 pm #132726
Sorry – there is nothing more I can add. This works.
If you want to save, say, test.sif as a sigfile, you have to use save as, and manually change the name to test.sif before hitting OK.
As I said, this works. If it really does not work for you, please give a full description of what you are doing, including EVERY keystroke, EVERY message, and EVERY thing you see, and send it to support@eventide.com, marked for my attention.
February 9, 2011 at 4:29 pm #132728
razo
MemberI did not specify the *.sig extension whe saving so it remained as a *.sif.
February 9, 2011 at 4:46 pm #132729
razo
MemberPerhaps it would be better if it is automatically saved as *.sig (when no extension is specified) and then as *.sif only if typed (if .sif is really needed.)
February 9, 2011 at 4:51 pm #132731
OK – I think you know what to do …
February 9, 2011 at 4:54 pm #132732
razo:
Probably so. sif format is essentially obsolete and will be removed from future versions. It's really only present for back-compatability.
