Home › Forums › Products › Stompboxes › Simple 7 Band EQ ALGO
February 14, 2018 at 7:34 am #114606
Custom Chris
MemberIt would be really great to come out with a straightforward 7 band EQ algorithm with no frills so I can save presets and not have to fiddle with my eq on my Mesa Mark IV amp between songs, or in song tone changes. If you made a separate Eventide Pedal with a 7 Band eq and 7 knobs below with (4) distortion sounds for each knob (provides 28 different distortion algorithms) depending on the position of knob that’ ranges from fuzz, mildly distorted to full blown low end crunch, I would buy it. Just sayin.
February 14, 2018 at 12:55 pm #148427
Tomtama
ParticipantCustom Chris wrote:It would be really great to come out with a straightforward 7 band EQ algorithm with no frills so I can save presets and not have to fiddle with my eq on my Mesa Mark IV amp between songs, or in song tone changes. If you made a separate Eventide Pedal with a 7 Band eq and 7 knobs below with (4) distortion sounds for each knob (provides 28 different distortion algorithms) depending on the position of knob that’ ranges from fuzz, mildly distorted to full blown low end crunch, I would buy it. Just sayin.It sounds like you want something like the Elektron Analog Drive pedal. Eight drive types in one pedal, 3 band EQ with sweepable mid, 100 presets, Midi controllable. https://www.elektron.se/products/analog-drive/
February 16, 2018 at 1:03 pm #148444
Custom Chris
MemberSeems like a good pedal. I get really good tones out of the mark v, but could use a (7) Band EQ that I could switch by simply changing banks. I guess I’ll fiddle some more with CrushStation (3) Band eq
February 16, 2018 at 2:35 pm #148445
gkellum
ParticipantCustom Chris wrote:Seems like a good pedal. I get really good tones out of the mark v, but could use a (7) Band EQ that I could switch by simply changing banks. I guess I’ll fiddle some more with CrushStation (3) Band eq
There's a nice parametric EQ in EQ Compressor as well of course. We've talked about making something like a 7 band EQ in the past, but it hasn't been one of the more frequently requested algorithms on the forums.
February 23, 2018 at 12:30 am #148503
Schilling
Participantgkellum wrote:Custom Chris wrote:Seems like a good pedal. I get really good tones out of the mark v, but could use a (7) Band EQ that I could switch by simply changing banks. I guess I’ll fiddle some more with CrushStation (3) Band eq
There’s a nice parametric EQ in EQ Compressor as well of course. We’ve talked about making something like a 7 band EQ in the past, but it hasn’t been one of the more frequently requested algorithms on the forums.
So let’s start requesting it.
+1
March 2, 2018 at 6:41 am #148556
mistercharlie
Participant+1 here, too. I already use the EQ Comp, but a slider-based graphic EQ would be easier to tweak quickly.
May 4, 2018 at 11:58 am #149151
davebrubaker
ParticipantA sweepable midrange would be ideal.
August 9, 2018 at 6:29 am #149883
flamefork
Member+1
August 10, 2018 at 12:13 pm #149886
davebrubaker
ParticipantAdd my vote to the list. If it could scoop the mids, that would be cool.
August 10, 2018 at 1:02 pm #149887
Schilling
Participant+1
November 3, 2018 at 11:04 am #150453
jm345
Participant+1
