October 28, 2008 at 2:09 pm #105899
lb1
MemberSomething very simple I am trying to do: use a continuous controller to take my signal and pan it from left to right in the stereo field. Toe up is the signal all the way in the left channel only, toe down on the pedal is the signal all the way in the right channel only, sweeping the stereo field as the pedal is swept up a and down. Pretty simple. I want to make sure that the volume is also constant and does not drop as the signal moves left to right, etc. Thats it.
October 28, 2008 at 2:28 pm #117975
IDeangelis
MemberHi
panning is preset base. It depends on whaich algorithm you are using. Those offering a PAN parameter will also give you the possibility to patch a CC to it.
The manual has a detailed section about how to assign any controller to a parameter.
As far as level, well…2 channels will always be louder than one. When the signal is in between the 2 extreme L/R positions, its level is obviously changing as this is the way panning works.
all the best
I
October 28, 2008 at 2:34 pm #117976
lb1
MemberUsing the fm panner as beginning algorithm
I set the CC into which parameter– width? T-Rate? FM Rate?
Which parameter controls the position in the stereo field, in other words? -
October 28, 2008 at 2:42 pm #117977
lb1
Memberpanning is preset base. It depends on whaich algorithm you are using.
>> which one do you suggest for my purposes specifically?
>>> FM Panner, strangely enough does not have a PAN parameter– so I guess I can't use it for this? What would be a better algorithm specifically?
In the Eclipse manual under algorithms, under
>>> Know how to do this. Not sure hich is best algorithm, best parameter to put the CC in
>>>> Absolutely. Relative volume is fixed
October 28, 2008 at 3:02 pm #129129
IDeangelis
MemberI don't know which is your "purpose specifically". There are so many effects in the unit. Need a panning delay? Or…?
FM Panner is an automated panner, controlled by an LFO which can be rate modulated by Envelope (input signal energy). It doesn't offer a L/R parameter that you can remote control.
What you really need to pan?
I
