? Simple “Effects Loop” Setup?
Home Forums Products Stompboxes ? Simple “Effects Loop” Setup?
    • #187608
      Skully027
        {I am using a a Friedman JJ jr and a 2×12 cab}:
        In the quick start setup manual.. they gave several setup pics, but I didn’t see an option to just:
        Plug the guitar cord into my amplifier front input jack.
        Plug the H90 Send/Return into the back of my amplifiers’ Send/Return. (3 cables total)
        Is this unit not sound good for that setup?
        They only showed a picture of guitar, to H90 to front of amplifier., as if you were using a stomp box with an amp that didn’t have a loop (2 cables total)
      • #187609
          The setup you describe will work just fine, if that’s how you want it to work.
          • Connect guitar directly to amp
          • Connect Amp Send to H90 input 1
          • Connect Amp Return to H90 output 1
          With this setup, all of your effects will be in the amps loop.
          You may also consider trying a Pre/Post setup. The H90 is great for this application, since it allows you to use effect in front of the amp, or in the loop of the amp: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/setup/pre-post.html
          Let me know if you have any other questions.
