simple h90 question :)
Home Forums Products Stompboxes simple h90 question :)
    • #168064
      willcrook69
        hi!
        using the h90 control software I’d like to be able to start fresh and build a preset, picking one effect then picking another one to go with it but whenever I go to pick an effect the only options are presets that already exist (some of which containing 2)
      • #168065
        joecozzi
          Hi willcrook69,
          If you do not wish to use the User 1 default “factory” Programs as your starting point you can go into the System Settings under Global and switch the Playlist to User 2, which has all INIT Programs that are empty. Regardless, any time you load an algorithm it will populate with a factory preset. You’re free to crate you’re own and store presets and programs.
        • #168071
          willcrook69
            how do I create my own preset and store it though?
            if I select a present with two different effects – one on A then one on B, I can’t change the preset for B because when I select a factory ‘preset’ to change the algorithm it replaces both of them
            • #168072
              coirbidh_99
                It’s important to keep the terminology here straight. In H90 terms, a *program* is the combination of *presets* loaded into slots A and B, plus the routing and performance mapping info that guides their interaction. To change a *preset* in your current *program*, use Presets Mode: https://cdn.eventideaudio.com/manuals/h90/1.1.2/content/edit-modes/presets.html.
              • #168073
                willcrook69
                  is there a way I can do this through the h90 control app as oppose to on the unit?
                • #168077
                  coirbidh_99
                    Click the “Preset Library” tab at the bottom of the screen.
