Six Op FM Synthesizer
Home › Forums › Products › Rackmount › Six Op FM Synthesizer
    • #106400
      ThreeFingersOfLove
        So, I have built myself a FM synthesizer with 6 operators in VSig. It's still in the works, the algorithm is not that complex, although it appears to be.
        I would like to find a way to compute the Index of FM for each oscillator (operator). The index = frequency deviation / frequency of the modulating oscillator. The Oscillator module has an audio input to modulate its frequency and a control input to adjust the depth. I can use a C_A to convert the signal to audio, and then route a.) the converted signal for depth (deviation) and b.)the frequency of the operator into a Divide module. So, the questions are:
        A. How do I route the output of the Divide module into a Menupage module, so that I can see the computed index?
        B. As it is, the index is computed, but is there a way to insert directly a ratio, like 4:3, into the oscillator?
        Thanks,
        Yannis
      • #118973
        A post for the Vsigfile folder, actually.
        You can't route anything to a menupage unless a module has the proper connection for UI. You may probably want to connect some kind of monitor to the DIVIDE to have something that can be brought up on a menupage.
        Don't think you can add a ratio to the oscillator. This may probably be done after it, using math/control math modules, if useful at all.
        best
        I
      • #158288
        moschops
          Could you share this Id LOVE to try this out, does it work in Vsig3?
