Small MIDI Controller for H9
Home Forums Products Stompboxes Small MIDI Controller for H9
Viewing 4 reply threads
    • #111423
      MrClean
      Hi Eventide friends, as a long term Eventide user its I ham now a fan of the H9 – loving the small footprint and the quality of its sound. I plan to add H9 core when available.  Im using an expression pedal with mine, but miss access to the hot switch on some of the Space Alg's. Is anyone aware of a small midi foot switch that would send a cc to the H9 to control this (and obviously other stuff if I wish)?? Any suggesting appreciated. or maybe Eventide dudes may think of making one if it doesn't exist !
    • #125488
      underwood
      there are not many small footprint midi controlers. I have build one for myself, because I only need a programm change function.
      greets
      Jürgen
    • #125489
      MrClean
      HI again, I found this – seems to do the job – DMC-2 MIDI Foot Controller Firmware: Eventide Factor / Space, http://www.disasterareaamps.com/shop/dmc-2 cheers !
    • #125497
      richpjr
      I've seen that Disaster midi controller.  One question I have on it is when you use it for a bank up/down selection, do you still need to hit the Activate button to select it?
    • #125508
      almogaver
      DMC-5K MIDI Foot Controller
      The DMC-5K seems designed to work best with the H9. The CC values are set up by default to interface with it.
      http://www.disasterareaamps.com/shop/dmc-5k-2
