Software update bug
Home Forums Products Stompboxes Software update bug
Viewing 4 reply threads
    • #105685
      dissever
      I experienced a unique sounding problem last night with the timefactor. On digital delay , in bypass(dsp/spillover), delay time A at zero and feedback up around 100% the pedal started to whine very loudly. It seemed to creep up and the sound could be altered with the moudulation and filter controls even while in bypass. It actually sounded preet cool with some attenuation and  a low pass filter but its not very pleasant if you dont expect it to happen.
    • #117570
      IDeangelis
       Not a bug!
      If you have a short delay, very short AND a high feedback setting, you create a weird beating sound as the delay buffer is filled with few audio samples and is recirculated very fast. It's a normal behaviour. Just be careful w/feedback settings.
      best
    • #117576
      DGillespie
      Yeah, this is intentional. It's what people talk about when they talk about sending delays into oscillation. It's great fun especially in mod delay, vintage delay, or tape echo because you can change the pitches by yanking the delay times back and forth. Version 2 also does this more easily because you can set the feedback values to 110% and use more aggressive filtering.
      Have fun but be careful, it can get loud
    • #128750
      dissever
       I use oscillation but this is different. It starts in bypass mode which I dont think anybody would want. Also the feedback does not need to be 100% to get it started.
    • #128751
      IDeangelis
       Very high feedback settings (75%) can create oscillation. You don't need 100%
      Also, the beating may start in bypass mode, depending on audio buffer being filled with signal at any time. Just be cautios.
      best
