Some H8000FW algos in plugins
Home Forums Products Plug-Ins Some H8000FW algos in plugins
Viewing 6 reply threads
    • #112095
      unguitar
      I am interested in checking if the following algorithms based on presets I tweaked on my H8000FW can be available on any of the available plugins:
      515 Envelope Taps
      2218 Super Ambient delays
      1844 Time Stretch Guitar
      thank you !
      Luca
    • #127059
      DGillespie
      Hi Luca,
      Unfortunately, IIRC, those are all based on a super multi tap delay algorithm we have, which is not currently available in plug-in land.
      I'm sorry,
      Dan
    • #127070
      unguitar
      Hi Dan,
      thank you for the reply.
      Is the H9 the only "light" available solution then ?
      thank you
    • #137698
      DGillespie
      Yes, the H9 UltraTap algorithm should be able to handle those kinds of effects.  The Eclipse can also do similar effects.
      Dan
    • #138963
      MacMoney
      How about some Steve Vai presets for the H3000?
      George Ware
    • #138981
      DGillespie
      I believe we've included all the potential presets, however, I'll look into it.
      Dan
    • #138990
      MacMoney
      Thanks so much!
      George Ware
