Some H9 for Bass GTR questions
Home Forums Products Stompboxes Some H9 for Bass GTR questions
Viewing 12 reply threads
    • #112595
      johnmarkpainter
      Are there any good Bass presets available for download??
      Interested in using the Octaver but it has a TON of Sub in it.
      Any way to Filter that I am not seeing?
      Also interested in Bass Wah that I have seen demoed on the ModFactor.
      Interested in replacing a few of the pedals on my board with the H9 but not sure if it really can.
      The pedals I am thinking I might be able to replace are Octaver, Chorus, Bass Wah.
    • #139201
      johnmarkpainter
      Been experiementing…
      Some of the other Algorithms in the Mangled Verbs in particular have a “Low and High Output”.
      That would be very useful in the Octaver.
      The Fuzz is close to being good as well but it has no Tone Shaping.
    • #139214
      gkellum
      Have you seen my colleague Russ's video where he goes through different algorithms he likes using with bass?
    • #139220
      johnmarkpainter
      I did see that.  Good video
      I was having a bit of trouble finding the right paramters/algorithms to work well with Bass.
      Getting my head aroud it now.
      For instance, in that video the refences the “Bass Wah” in the ModFactor…I finally found it.
      Still getting used to how the parameters are laid out in the H9.
    • #139227
      LA Keys
      Did you set the “source instrument” to Bass?  (This is under Pedal -> General settings.)
      I don’t really know how much impact this have on the parameters since I’m actually using the H9 with keyboards and never tried a different setting but since Eventide put something there it should somehow affect the sound…
      LA
    • #139228
      johnmarkpainter
      WOW!  Nope….
      It says it adjusts the range of the Filter knobs.
      Thanks for that one.
    • #139230
      wedelich
      Bass mode also adjusts the pitchshifting algorithms to be able to track the lower notes of a bass guitar.
    • #139240
      johnmarkpainter
      Do the changes affect Presets you have already made or do you have to start from scratch?
    • #139242
      wedelich
      You don't have to resave presets when you change the source to Bass.  It should just alter the settings in your current presets such that they are more "tuned" for lower register instruments.  This mostly applies to the PF stuff and a few filters cutoff frequencies here and there.
    • #139245
      spaceJam
      I’m wondering if one can asign and save the “Source” value per preset. Or even better, with CC.
      I sometimes use my guitar to loop bass lines on my band since we don’t have a bassist and having presets with emphasis on the low notes would be amazing.
      Couldn’t find anything in the manual, but maybe for the next pitchfactor/H9 update?
    • #139248
      Alas, the reply is no and no. Do you find that it makes so much difference ?
    • #150338
      Mimmomix
      Hi jhon, using not only octaver but also others (modullators, arpeggiators, delay too) i have the same ton of sub in them.
      Have you resolved the matter?
      I’m very interest in it.
      • #150339
        johnmarkpainter
        Mimmomix wrote:
        Hi jhon, using not only octaver but also others (modullators, arpeggiators, delay too) i have the same ton of sub in them. Have you resolved the matter? I’m very interest in it.
        Sorry..,no.
        I resolved it with an MXR Bass Octave Deluxe and currently with an HX Stomp
    • #153199
      Mimmomix
      Hi everbody!!! Some news about this? I really was waiting for improving to solve this gap. But nothing, seem to me, has happened yet.
      I have yet my two H9, but they are unsable because too much bass and sub bass!
      Let me know.
      Ciao.
