Home › Forums › Products › Stompboxes › Some Random H9 Presets
April 12, 2015 at 4:48 pm #112497
Many H9 algorithms feature Random or Sample and Hold modulation. They can add rhythmic interest and unpredictable nuances to your presets, ranging from subtle enhancements to uncontrolled chaos.
When I first received my PitchFactor, I was pleasantly surprised by some of the Harpeggiator functions. I wasn't expecting the ability to create all kinds of "multi-effects". The first task was to create a MIDI sync version of my Oberheim VCF-200.
The expression pedal mapping was simple: DYNAMICS is inactive with no RHYTHM pattern enabled. The pedal brings up a rhythm pattern; giving a sharper attack to the S&H filter sequences.
Expression Pedal Heel RHYTHM A OFF
Expression Pedal Heel RHYTHM B OFF
Expression Pedal Toe RHYTHM A 01
Expression Pedal Toe RHYTHM B 01
That led to many more discoveries using random modulation in the HarPeggiator. And now it's extended to the other H9 algorithms. Sample and Hold [quantized random modulation], and (truly) Random modulation are mainly found within the ModFactor algorithms. More presets to come …
April 12, 2015 at 5:38 pm #127717
Expression Pedal Heel MOD RATE 8.000xSPD
Expression Pedal Toe MOD RATE 0.125xSPD
April 12, 2015 at 5:43 pm #127718
Expression Pedal Heel INTENSITY 25
Expression Pedal Toe INTENSITY 75
April 12, 2015 at 5:50 pm #127719
Expression Pedal Heel SPEED 1976Hz
Expression Pedal Heel DEPTH MOD 50
Expression Pedal Heel SPEED MOD 50
Expression Pedal Heel MOD RATE 0.500xSPD
Expression Pedal Toe SPEED 2637Hz
Expression Pedal Toe DEPTH MOD 99
Expression Pedal Toe SPEED MOD 99
Expression Pedal Toe MOD RATE 1.500xSPD
April 12, 2015 at 5:56 pm #138828
The Mother of Randomizing Presets … You've been warned.
Expression Pedal Heel RHYTHM A 06
Expression Pedal Heel RHYTHM B 06
Expression Pedal Toe RHYTHM A RANDOM
Expression Pedal Toe RHYTHM B RANDOM
April 12, 2015 at 6:01 pm #138830
Expression Pedal Heel LENGTH 1/16
Expression Pedal Heel DYNAMICS 5
Expression Pedal Toe LENGTH 1/4
Expression Pedal Heel DYNAMICS 3
April 12, 2015 at 11:11 pm #138839
Expression Pedal Heel ROTOR SPD 1/4
Expression Pedal Heel HORN SPD dotted 1/8
Expression Pedal Toe ROTOR SPD 1/16
Expression Pedal Toe HORN SPD dotted 1/2
April 12, 2015 at 11:17 pm #138840
Expression Pedal Heel SPREAD 25
Expression Pedal Heel SPEED MOD 0
Expression Pedal Heel MOD RATE 1.000xSPD
Expression Pedal Toe SPREAD 99
Expression Pedal Toe MOD RATE 4.000xSPD
April 12, 2015 at 11:20 pm #138841
Expression Pedal Heel SPEED 1/4
Expression Pedal Toe SPEED 1/16
April 12, 2015 at 11:27 pm #138842
Expression Pedal Heel MIX 10
Expression Pedal Heel DYNAMICS 0
Expression Pedal Heel LENGTH 100 mS
Expression Pedal Toe MIX 100
Expression Pedal Toe DYNAMICS 5
Expression Pedal Toe LENGTH 10 mS
April 12, 2015 at 11:31 pm #138843
Expression Pedal Heel MOD RATE 4.000xSPD
Expression Pedal Toe MOD RATE 8.000xSPD
April 12, 2015 at 11:35 pm #138844
Expression Pedal Heel MOD RATE 0.750xSPD
Expression Pedal Toe MOD RATE 2.000xSPD
April 17, 2015 at 12:15 am #138873
Expression Pedal Heel SPEED 0.50Hz
Expression Pedal Toe SPEED 1.00Hz
April 17, 2015 at 12:20 am #138874
Expression Pedal Heel INTENSITY 15
Expression Pedal Heel SPEED 1/16
Expression Pedal Toe INTENSITY 99
Expression Pedal Toe SPEED 1/2
April 17, 2015 at 12:27 am #138875
Expression Pedal Heel LENGTH 125mS
Expression Pedal Heel EFFECTS A RNM
Expression Pedal Heel EFFECTS B RNM
Expression Pedal Toe DYNAMICS 10
Expression Pedal Toe LENGTH 10mS
Expression Pedal Toe EFFECTS A RNFl
Expression Pedal Toe EFFECTS B RNFl
April 17, 2015 at 12:32 am #138876
Expression Pedal Heel END VOWEL B .. EA .. T
Expression Pedal Heel START VOWEL B .. IR .. D
Expression Pedal Toe END VOWEL B .. IR .. D
Expression Pedal Toe START VOWEL B .. EA .. T
April 17, 2015 at 12:35 am #138877
Expression Pedal Heel DEPTH 50
Expression Pedal Toe DEPTH 99
Expression Pedal Toe SPEED 1/4
April 19, 2015 at 10:46 pm #138894
April 19, 2015 at 10:49 pm #138895
Expression Pedal Heel TYPE RETRO
Expression Pedal Toe TYPE MODERN
April 19, 2015 at 10:55 pm #138896
Expression Pedal Heel SPEED 4.00Hz
April 19, 2015 at 11:17 pm #138897
Expression Pedal Heel DECAY 4 BAR
Expression Pedal Heel PRE DELAY 1/4
Expression Pedal Heel SPEED 1/8
Expression Pedal Toe DECAY INF
Expression Pedal Toe PRE DELAY NONE
April 21, 2015 at 12:47 am #138903
A couple more great batches of presets, Brock, quickly building quite a library of special effects. Your work really shows the way to expand the possibilities of the ET stompbox algos. Thanks!
April 25, 2015 at 2:24 am #138939
Maybe I should start a bread 'n' butter presets thread, or classic FX box emulations. Lately, I've been re-discovering one semi-common aspect among the H9 algorithms, and exploring it thoroughly.
Here's one similar preset that I neglected to add:
Expression Pedal Heel DEPTH MOD 99
Expression Pedal Toe DEPTH MOD 0
April 25, 2015 at 8:10 pm #138944
A more subtle approach to random modulation:
Expression Pedal Heel SPEED 2.00Hz
Expression Pedal Toe SPEED 10.00Hz
April 26, 2015 at 10:34 pm #138951
HotSwitch Off TAPS 16
HotSwitch On TAPS 64
Expression Pedal Heel LENGTH 750 mS
Expression Pedal Toe LENGTH 4000 mS
May 3, 2015 at 10:30 pm #139000
I couldn't resist adding this one. Hit Slow/Fast for a less rhythmic – and more sustained – sound. The expression pedal counterweights the S&H rates for even more randomness.
Expression Pedal Heel MOD RATE 2.000xSPD
Expression Pedal Toe MOD RATE 0.500xSPD
