Home › Forums › Products › Rackmount › Sorry ,I’ll explain more simply my MIDI problems with Eventide H8000fw
February 21, 2011 at 6:29 pm #107652E.M PulinxMember
Sorry ,’ll explain more simply :
Let assume that
On Disp A I have glorious Chrs Canyon
B Galaxy borders 2
On Galaxy borders2 , I take the machine B mix page ( with the key “levels”)
I press and hold the select key and do a remote control of “levels”. That’s all what I want. Now, with my Roland vol pedal, I can go from Wet/dry 0 to 100% in the 8 channels B OUT 1 TO OUT 8 in disp B Galaxy borders2.
When I return to “parameter “ in Galaxy borders2 , we have 4 soft keys.
The first is called ” eq” in this Prg. The first line of eq is” low -18dB.”
When I hit the pedal in order to vary the wet/dry levels of Galaxy borders ,this parameter “low -18dB “ is also responding to the pedal, going from -18 to +18 dB . WHY ? I never assigned this parameter for remote control,only global wet/dry levels !
If I press the 2nd soft key, “reverse” ,that’s now : t_length 13/16 note who will vary with the pedal from 13/16 to 1/64 note .
Again ,why ?
In DispA, glorious Chrs Canyon, I didn’t nothing regarding Midi assignement.
However, when I hiT the key PROCESSOR A/B ,Glorious chrs Canyon appears in the screen.
The first parameter of the 1st soft key " reverb" verb level -3dB will also obey to the pedal ,and also the Out 1 wet/dry parameter of Glorious Chrs Canyon .The others OUT 2 TO OUT8 do not obey . Why verb level and OUT1 wet/dry of DispA Glorious Chrs canyon does respond to the vol pedal? I didn’t assign anything remote regarding Disp A
Cheers
EMP
February 21, 2011 at 7:50 pm #121595
Thanks. That's better. But, I cannot duplicate your problem.
My guess is that the internal ram is corrupted, maybe as a result of not doing a CLEAR SETUP after an upgrade. Either way, a CLEAR SETUP will probably fix it, at the price of removing any of this sort of remote programming that you have done.
Another approach would be to look at the knob controls that are misbehaving – I suspect is that if you press and hold SELECT, you will probably see that they already have remote connections assigned. Or, look for the flashing underline under the name.
February 21, 2011 at 8:17 pm #121596sean.eParticipant
If the controller in use for levels was also assigned to MIDI Groups, would that explain the behavior?
February 21, 2011 at 8:46 pm #132814
It might, but MIDI groups tend to reference (say) all the knobs on a single screen from multiple MIDI sources – his problem is probably more like the opposite, where a single MIDI source affects multiple unrelated knobs.
But, on the other hand, you may be suggesting this because the same thing happened to you …
February 23, 2011 at 11:18 am #132818E.M PulinxMember
TRYING TO REMOTE THE LEVELS AND SOMETHING WRONG hAPPENS IN THE PRESET PARAMETERS
I have the impression that a bug does exist in the remote of group levels ,like a few years ago in one of my Orville.
I have done your suggestion :
I have tried to go in the remote control page of "Levels" :mode is on "volume",as I had made it.
But contrarely as you said,when I go in the remote control of individual parameters who respond to my "volume command" , Mode is OFF and Capture midi is off !!!
Can you speak of this problem to the engineer taking care of the H8000 system ?
Emil
February 23, 2011 at 4:13 pm #132822
I'm sorry – I cannot understand you. Please be less excited, avoid all capitals and bold, and give a clear explanation of exactly what you did and exactly what you saw, rather than this vague description. Otherwise I cannot help.
