Home › Forums › Products › Stompboxes › Space
February 22, 2011 at 5:55 am #107655
spacestation
MemberHi, I'm new here and I just preordered the SPACE from Novamusik.com
Questions:
– When do you expect to deliver to the above retailer – roughly when can I expect to receive the item?
– I live in the UK thus will be using UK mains voltage…is this a problem? I power everything with a Visual Sound 1 Spot (9V) power supply, will I be able to use that or should I only use the designated PS?
Many thanks!E
February 22, 2011 at 4:34 pm #121601
Hard for us to say when it will be delivered as there is quite a queue – it will depend when your dealer placed the order to us.
Best that you contact your dealer – he should have the best idea.
UK mains voltage is supported, so no problem there. We can only recommend the use of our power supply, for obvious reasons. Your power supply manufacturer should be able to tell you if he can handle our pedals. He won't know SPACE, cos it's new, but the power requirements are similar to the TF/MF/PF.
February 23, 2011 at 2:24 pm #121603
usehername
MemberDid the first run ship to dealers?
February 23, 2011 at 7:20 pm #121607
spacestation
MemberThe retailer says that they expect it in the second week of March, adding that they typically have the
Pre Order items a few days early and it would be just a matter of
waiting until the manufacturer allows them to release it….I'm going on the road in mid March and would love to take SPACE with me… so I hope that Eventide will press the 'release button' soon! Any news on that would be highly appreciated. -
February 23, 2011 at 7:31 pm #132825
Imerkat
ParticipantDid Nova Musik say this??? i'm on their list too!
February 24, 2011 at 12:56 am #132831
spacestation
Memberyeh….. but shhh!
February 27, 2011 at 8:46 pm #121628
badmelonfarmer
ParticipantCan't comment on Space as it is not release, but assuming it is the same as all the other Factors that I have owned… you CAN power them with a OneSpot… use a OneSpot "L6" conector to get the right connector size.
The issue with all this is that the Factors need isolated power, so you can not chain a factor with other pedals unless you are using an isolating outlet supply…. OneSpot is not isolated.
there are other power supplies that will work, but obviously Eventide only support / recommend the official ones as they know they work and will not damage the box.
February 28, 2011 at 4:20 pm #121633
spacestation
Memberthat's very useful to know, as I don't own any other factor pedals.. thanks!!
February 28, 2011 at 5:11 pm #132857
badmelonfarmer
Participantno worries man, happy to help
March 1, 2011 at 12:54 am #121640
guitarlesson
MemberWait, so just for ABSOLUTE clarity… you can use 4 OneSpots to power 4 factors, but you cannot chain them to one supply, right? I understand that one OneSpot would probable not supply enough amps since my TF requires 1.2, but isolation is something I know little about. Thanks.
March 1, 2011 at 9:41 am #132864
badmelonfarmer
Participantguitarlesson:
Yes that is correct. basically you have to have one power supply dedicated to one factor. you can not have multiple factors on the same onespot or even a simple compressor and a factor on the same onespot.
The exception to this is the power supplies that isolate each output…. like the powerfactor etc…. these power supplies are usually a lot more expensive.
