SPACE Bypass
Home Forums Products Stompboxes SPACE Bypass
Viewing 5 reply threads
    • #159943
      Daniel
      Forgive my ignorance, but when my SPACE pedal is in DSP or DSP+FX Bypass, is my signal buffered when the pedal is on and off?
    • #159944
      joecozzi
      Yes
    • #159945
      Daniel
      Thank you, Joe.
    • #159981
      MagnusC
      What’s the difference between these two bypass modes?
    • #159982
      joecozzi
      Most notable difference is that when a pedal is in DSP+FX mode, the reverb tail will continue to ring out after the pedal has been bypassed.
    • #160586
      weirdmayo
      The point of DSP+FX is that when you deactivate the pedal/effect, the trails from the Reverb or Delay are still present, instead of suddenly cutting off. That way you can enable huge reverb, set up some sort of strike effect/drone background, and then disable it and play over it. Or something like that.
      If you don’t need that just put it into Bypass if you so desire. Or regular DSP. That way the reverb will be cut off completely as soon as you deactivate the pedal.
