Home › Forums › Products › Stompboxes › Space / Clock Out
April 8, 2017 at 4:53 pm #146088
I'm guessing NO. There is not (as far as I know) such a thing as a MIDI to jack cable.
Theoretically, you could make a MIDIclock to jack closure cable, but I'm not aware of anyone who does.
April 9, 2017 at 2:38 pm #146089Hellmaster92Participant
Thank you for the answer !
Lehle actually sell a MIDI to Jack cable :
http://lehle.com/FR/Lehle-MIDI-Kabel
I mailed them too, we’ll see…
Another solution would be the Disaster Area Smart Clock, but there is a huge difference between a 17 € cable & a 180 £ controller…
Does anybody has other informations ?
Thanks
Rémi
April 9, 2017 at 4:25 pm #146090supportwallirecMember
April 10, 2017 at 11:54 am #114107Hellmaster92Participant
Hi guys,
I have a question : is it possible to transmit a tempo information with the Space ?
I’ll buy a analog tremolo pedal soon, and I wish to have one with a tap tempo input. Do you think it’s possible to send tempo information wih the Space ? If I buy a MIDI to jack cable, and if I plug it from the Space’s MIDI OUT to the Tap Tempo Input, will it work ?
I know there is a MIDI CLOCK option in the Eventide stompbox. I use to do it with my Pitchfactor to send tap tempo to an Arturia Minibrute. But the Arturia has a Midi Input, whereas many pedals just have a jack input for tap tempo.
Thank you in advance
Rémi
May 2, 2017 at 4:12 am #146275camnParticipant
maybe a cheaper option, if your setup allows… use an Aux switch for tap tempo.. and split it to both the H9 and the Analog Tremelo?
