Home › Forums › Products › Vsig and Preset Development › Space Freeze function in VSig
August 30, 2016 at 3:40 pm #113668
marvingain
ParticipantHi everyone!
First post on the forum, and have a hardcore patch design question already 🙂
I recently sold my Eventide Space, and I’m really missing the Infinity and Freeze features on the different presets on the Space.
I have an Orville as well which i very much prefer the sound of, but i can’t seem to find a Freeze function anywhere except for a repeating delay in the “freeze 2 beats” preset.
This makes me believe it is possible to recreate the reverb freeze function on the Orville using VSIG… But how?
Any help here is really welcome! 🙂 -
August 30, 2016 at 6:20 pm #144227
You would need to set the reverb decay parameter to its maximum and kill the input. This means that whatever is in the reverb stays there. A bit like Vegas.
The skill is to do this without putting clicks into the reverb which will then hang around for a long time. I'll leave this bit to you.
August 31, 2016 at 2:16 pm #144242
marvingain
ParticipantHi and thanks for the quick response!
So that’s all it is to the Space freeze function? Setting a reverb decay time to 1000 sec should be close enough then? Or is there a way to set it to true infinite? Clickless kill should be able to be achieved via the iswitch module?
September 1, 2016 at 1:39 pm #144252marvingain wrote:
So that's all it is to the Space freeze function? Setting a reverb decay time to 1000 sec should be close enough then? Or is there a way to set it to true infinite? Clickless kill should be able to be achieved via the iswitch module?
1000 seconds should be enough … don't forget to cut the input as well.
ISWITCH sounds relevant, but that bit is for you to work out.
