Home › Forums › Products › Stompboxes › Space in FX loop is clipping
So it seems the FX loop in both my pre-amp and my amp are both to hot for the Space input as I'm in the red no matter what I do. Anyway to fix this?
Did you set Space's input switch to Line?
yes, it clips…red led comes on…
is there a way to adjust the levels?
You can only adjust the input level with the switch. What kind of amp is it? Maybe it has an effects send level control?
I got it sorted out. I was using the wet/dry knob on the preamp-loop and I needed to lower the master level on the preamp channel…
here's my rig: http://nervenickels.com/RIG2011.jpg
However, if I want to use the loop in the amp vs. the preamp it would clip…
